I'm trying to use Pftrack, and I managed to export a .clip file to Houdini, but the problem is that I think this file only relates to the camera movement. But what I really want to import to Houdini is the object tracking (but it seems Pftrack only does it to shake). Am I right? Can I export to houdini the object tracking instead of the camera tracking?
Thank you in advance
Tiago
Pftrack and Houdini
7012 6 1- tiagovsantunes
- 21 posts
- probbins
- 1145 posts
No, any data that PFtrack spits out should be able to go to Houdini. There isn't anything particularly magical about the data, it's simply lists of coordinates.
I haven't opend PFtrack for a while, perhaps there is an option you need to turn on?
“everything is coincident”
- tiagovsantunes
- 21 posts
thanks probbins,
the thing is in pftrack there's an option called “2D tracking exports” and an option called “3d camera exports”, the first doesn't export to houdini, and when I used the second one it only gave me the camera data, but has you said, maybe I didn't use the proper preferences. The manual isn't very helpful as well… I'll keep on trying,
thanks
Tiago
thanks
Tiago
- probbins
- 1145 posts
- tiagovsantunes
- 21 posts
- aracid
- 154 posts
- tiagovsantunes
- 21 posts
