disable opencl and preconditioner faster than enable each of
   1806   8   0
disable opencl and preconditioner faster than enable each of them?
im using houdini 17.5
my cpu e5-2695 v4*2
my gpu quadro p5000
this is my test resuit(fluid)
3.12 opencl
2.32 preconditioner
2.29 disable all
this my project
testbkup.hip (2.2 MB)
didn't check your setup but it shouldn't be a surprise - preconditioner is for quad-core setups IIRC, openclgpu runs across the slow PCI bus. 1 puny gpu card vs 72threads of cpu goodness…
Try openCL CPU, in misc prefs. in theory that should be faster .
山羊
thanks, I was wrong, I thought that opencl means something like cuda can speed up by gpu and cpu ,does houdini has gpu acceleration or somthing like that?
goat
opencl cpu 2.47, disable still win, strange
that machine is beast!
here, 500 frames:
Ryzen 2700X ~15min
with 1080ti ~8min
goat
here, 500 frames:
Ryzen 2700X ~15min
with 1080ti ~8min
what? no no no
I forgot to save when I uploaded the file,thats my 100 frames resuit
seriously???15m,8m???
500frames:
28m28s
I am really confused now , thats crazy
AH I see your test now, at the object level where it meshes, so…
CPU only
100 frames 1m 45s
Linux should give you a boost. OpenCL doesnt affect 100 frames that much. It only works on the viscosity and pressure in DOP land IIRC - good news, though, H18 optimises flippy
Edited by anon_user_37409885 - Nov. 5, 2019 13:39:01
version 18 going to be very impressive for large scale with my 2990wx muahahahaha
It’s amazing, I will definitely buy amd next time.
