Hello everyone,
Today I started my journey with Houdini and with that come first problem and questions. I manage to successfully create RBD Glue FBX imported object.
First question is how can I create custom ground for my RBD - if I use my OBJ ground everything is falling through (I tried object as flat plane and later with extruded thickness)I even try to create normal ground plane and change it into terrain obj I imported.
Second question is about textures. My object is FBX game model of townhall. I manage to import it into Houdini with the textures. Everything was great until I add RBD Glue which totally hide my textures. I check nodes and they were like before in main file tree but texture after applied RBD dissapear.
Thank you for any advice
Custom ground and disappearing textures
546 0 1- DrPhil
- 1 posts
