RenderView for LOPS
   3395   4   1
I'm wondering if there is a plan for a renderview that supports STAGE? Rendering in the viewport is going to be a bit problematic when you have large scenes. And be able to compare with previous render… well, you get the point
Anyhow, the STAGE context is the best thing since sliced bread
all the best
stefan
CG Supervisor - Important Looking Pirates
http://www.ilpvfx.com/ [www.ilpvfx.com]
yes
https://www.sidefx.com/faq/karma/ [www.sidefx.com]
Does this mean it will support 3rd party render engines to use the renderview?
It'll be a bit silly and very crucial if you can't use the renderview with 3rd party renderers, such as PRman.
I am wondering the same thing, whether there will be a “unified” renderview for all renderers, or if third parties will be responsible for implementing their own. Maybe it's too early to even ask as this point, SideFX mentioned that a render view is part of the “long-term” plan. I'm really hoping that's because USD is still a moving target and not because a render view is not a high priority. As nice as the Hydra IPR stuff is, it's no substitute for a full-featured render view/frame buffer, and without that it's really not a complete look-dev/lighting/shading solution IMO.
Edited by Siavash Tehrani - Jan. 29, 2020 12:27:51
Yuri Serizawa
The renderview already supports other renderers. Any renderer with a Hydra supporting plugin should work.
