Hi!
First post here! I'm new to Houdini. I'm loving it so far but I've run into a roadblock which has stopped my fun! I'm hoping one of you will have some ideas.
I've setup a scene where I can paint with a brush to control the size of the boxes on my grid. However when I wanted to start using the @Cd to control the number of copies in the copy node, everything breaks. Having a little background in shader writing I want to guess that this is because the scale is a float vector so the data plugs in fine, but the “number of copies” in the copy and transform node is an integer and can't accept the data being passed through @Cd?
How would I go about stacking boxes( to be replaced later with skyscraper/building floors) with control over the number of stacked objects via painted weights? I was able to set this up to work with a random value but I really want artistic control over the number of stacked copies.
For context I should probably mention that I'm trying to setup a sci-fi city where each cube(building) on the grid will be replaced with a custom sweep profile and then stacked on top of each other to create each “story/floor” I assumed using the copy node with number of copies and a translate value of 1 would do the trick but I'm definitely not attached to the idea if someone has a better one please do share!
Help needed! How can I setup painted control over integers?
562 0 0- joelDurham
- 1 posts
