I have this issue where want to pack some geometry into UDIM tiles but the largest packable option does not pack each prim group into the maximum UDIM space.
I have attached the example file.
The setup:
- create name attrib for each primGroup: Group1 becomes piece1…
- for each group, assign a udim attribute: piece0 becomes 1001…
- feed udim int attribute tag into UVLayout node.
The result:
The UVLayout node nicely packs each primGroup into it's designated UDIM space, but even with the Packing->Largest Packable option enabled, it barely fills the UDIM space. It looks like it's trying to keep the primGroups in proportion to each other.
P.S.
I did a workaround where i for loop each primGroup seperately and it works perfectly with the UDIM space packing but that method disconnects each primGroup and changes my point order for which i have no means to restore and in turn, ruins my workflow.
