I guess im wondering what would be the correct PDG workflow for:
1- Create a piece of geometry like a rock (easy)
2- have a topnet that does wedges of it (say 5 different easy)
3- create a usd file from this wedges, and configure each of the variants from the resulting bits of geometry as a ‘model’ variant for that first rock in a usd
4- then, at the end, save a usd file of this with the model variants, etc.
I had a look around but I don't see any tutorials that combine usd and pdg workflows..
Any thoughts ?
Pdg based usb model variants ?
3128 5 2-
- Sixjames1000
- 52 posts
- chrisgreb
- 603 posts
- Sixjames1000
- 52 posts
I see. Is there a chance of a small example? I tried having the wedge'd out object, imported as a sopImport in lops and had a look at the for each node, but Im unsure how to get it to perform with add variant to existing primitive and the pdg_input set of work items..
If you happen to be able to show us a quick example, that would be super appreciated! Otherwise I'll keep trying
- chrisgreb
- 603 posts
You would need a `waitforall` TOP before the ROP USD to gather all the geo files, then I expect you could use `@pdg_input.N` to get the input file path for each iteration in LOPs. If the number of variants is fixed you could start by hard coding the `Add Variant to Existing Primitive` nodes so you don't have to worry about iterating. I don't have an example for you now (will have time after next week), but you might have better luck asking on the Solaris forum or submitting a question to support.
- Sixjames1000
- 52 posts
I've done a couple tests but I am stuck in how to load the resulting wedges into the LOPs addVariant loop.
I've also posted a new thread on the Solaris forum.
https://www.sidefx.com/forum/topic/71275/?page=1#post-302119 [www.sidefx.com]
- chrisgreb
- 603 posts
