Setting up json package environments
   3998   6   0
we are trying to setup showwise envrionments in the project.json files for our current pipeline. we are follwing below procedure for the setting up the envs.
Link: https://www.sidefx.com/docs/houdini/ref/plugins.html [www.sidefx.com]
Topic: Set package folders dynamically
We put an project.json file under $HOUDINI_USER_PREF_DIR/packages or $HFS/packages directory.
project.json:
“env”:
“package_path”: “/Drive/Project/common/packages”
In /Drive/Project/common/packages path, below .json files are there.
asset_a.json:
“env”: [
“Char_a_TEX”: “/Drive/Project/assets/Char_a/published/textures”
“HOUDINI_PATH” : “/Drive/Project/assets/Char_a/common/otls
asset_b.json:
”env“:
”Char_b_TEX“: ”/Drive/Project/assets/Char_a/published/textures"
Issue is that it is not working. We are unable to find the declaired environments Char_a_TEX and Char_b_TEX and also the hda file in the Houdini_path do not show inside houdini.
So can you please look in to above procedure and guide us with proper process.
Thank you
Anibrain India
package_path is not meant to be set as an environment variable. It's rather a package attribute that needs to be set outside the “env” object like so:
"env" : [
{"FOO" : "$HOME/bar"}
We set like this. It does not work.
Anibrain Tech India
Make sure “/Drive/Project/common/packages” is a valid path. Here's how I'm using it:
// C:\Users\marcb\houdini18.5\packages\package.json
"package_path" : "c:/temp/foo"
// C:\temp\foo\package.json
"path" : [
"/home/bob/bob_tool"
. hconfig -xa
= = = Houdini Package log = = =
Processing 'C:/Users/marcb/houdini18.5/packages/package.json'
Processing 'c:/temp/foo/package.json'
HFS := 'C:/Users/marcb/DEV/HOUDINI/dev/hfs'
HOME := 'C:/Users/marcb'
HOUDINI_DESKTOP_DIR := 'C:/Users/marcb/Desktop'
HOUDINI_OS := 'Windows'
HOUDINI_PACKAGE_VERBOSE := 1
HOUDINI_PATH := '/home/bob/bob_tool;&'
HOUDINI_TEMP_DIR := 'C:/Users/marcb/AppData/Local/Temp/houdini_temp'
HOUDINI_USER_PREF_DIR := 'C:/Users/marcb/houdini18.5'
SHELL := 'C:/PROGRA~1/Git/usr/bin/bash.exe'
USER := 'marcb'
Edited by mabelzile - Jan. 7, 2020 09:07:41
running Houdini 18.0.287 / 17.5.216
log:
Processing: ‘/Drive/Project/common/packages/package.json’
ERROR: Unsupported setting ‘package_path’
Anibrain Tech India
log:
“package_path” was added to 18.0.315
mabelzile
Anibrain Tech India
log:
Thank You. It is working in latest build..
