Hi, I'm having trouble overriding the scheduler for a python script pdg node. The default for all nodes is a local scheduler, but for this specific node I want to send to the farm (hqueue scheduler). It looks like it is always executing locally, no mater what its scheduler parm is set to.
What am I missing here ?
I'm on Houdini 18.0.348 btw, seen a lot of updates related to HQueue/PDG on later versions, but I'm not sure I need to update to use this. (preferrably not, if possible)
thanks
Sending Python Script nodes to HQueue (not working)
2229 2 1-
- fabriciochamon
- 79 posts
- tpetrick
- 616 posts
- fabriciochamon
- 79 posts
Hi Taylor,
Thank you, this indeed works, sorry for the noise (Chris also helped me out on the Discord channel). Just for the records, my problem was that I was changing the python node (poiting the other scheduler) and trying to recook right away. Looks like I also need to regenerate the node, otherwise Hqueue would not pickup the changes. I took me a while to realize this.
thanks.
thanks.
