Making more complex curves
   2751   5   0
I seem to have stumbled onto what I can only assume is a Houdini weak spot. Curves. I have to draw a path for an object which starts and ends with some straight bits and has 2 spirals in the middle, so i made the two spiral parts using the curve tool and a twist sop, and made the straight bits using the curve tool and the odd transform. Now I need them to be one curve so i plug them all into a merge sop and then a fuse. The point order is screwed and the sort sop is of no use so I'm wondering if i really need to go back to softimage just to generate this curve, or am i missing something fundamental? Attached is the simple i've been using so you can see what I've been up to.
cheers,
A.
Edited by Andi Farhall - Feb. 26, 2020 11:00:18
curve_hell.hip (178.0 KB)
I suppose you could use the findshortestpath sop to resort your points
Edited by off_by_one - Feb. 26, 2020 11:36:22
curve_hell.hip (186.7 KB)
Thanks Benny, that certainly works. To me it appears to need some convoluted thinking to have reached that solution myself but then I've only had 12 months experience at the simplest end of Houdini so my brain is still working in oldschool soft mode. Now I'm out of that hole I can crack on.
cheers,
A>
merge, join, sort…
can be awkward at times, Houdini is very sensitive to point order
curve_hell_g.hip (164.8 KB)
Training Lead
www.sidefx.com
Thanks Michael…. Infinite ways to skin a Houdini cat, and every day learn something new.
cheers,
A.
I find the polypath tool auto-finagles any jumble of curves pretty well.
