Can I cook a list of Top networks with another "Main" Top network?
   2104   3   1
I want to cook several Top network one by one. Can I use another Top network to manage other Top networks?
Actually I've made a node to do this job, it works but I wonder is it the right way to do this or there's any better solution.
I know there's a Top Fetch node, but it run Hython background and I can't really see what's going on inside that Top network.
If you need the node I'm willing to share it, Thank you.
Edited by EricSheng - March 2, 2020 04:00:25
That's probably the best way. We do have an existing RFE to support in-process top fetches.
chrisgreb
Hi, Chris:
Thanks for your reply, I've made a node to do this but it'll crash Houdini instantly when it comes to complex node graphs. I guess I do it wrong, and it has many works to do than I thought.
If you are triggering a cook of a different graph using python HOM, make sure that gets executed on the main thread with hdefereval:
import hdefereval
hdefereval.executeDeferred(myfn)
