How to draw text in the viewport regardless of viewer state?
   12379   20   3
I'm working with music, and I'd like to put beats and bars in the corner of the viewport. Not dissimilar to the fps/render time display you can enable with Display Options > Guides > Show Time.
I've got an external MIDI display working by registering a callback with hou.playbar.addEventCallback() so I imagine I'd need to take a similar approach, but how do I actually write a string of text to the viewport?
The only clues I've got are the custom viewer state examples in the docs; there's a text_drawable object I could create but I'm not sure how to actually tie its draw function into things.
Suggestions etc appreciated
You need to write a python state for drawing text in the viewport. Use the code generator to create a blank python state and use viewerstate.utils.HUD to add your text. There is an example in $HH/viewer_states/examples/state_dragdrop_demo.hip to demonstrate how to use it.
This seems to create a new viewer state though - ie the text will disappear the moment I exit it, say, by hitting Escape to go into viewport navigation mode, or Enter to use a handle/manipulator.
I'm trying to create a persistent UI element, independent of viewer state: is this not possible with Python?
You can add The OGL Viewport Comment (vcomment) property to camera from render properties section of spare parameter editor.
Ha! That's spectacular. I'd never have guessed that existed… crikey, I'm going to be using that for all sorts of feedback now. Thanks!
howiem
You can write a nodeless python state that can run in multiple contexts. But yea you currently need a python state, there is a bug logged however to draw text in the viewport (via a callback probably).
Cool. A TC/beats display may as well have its own pane you can put where you like, rather than being in the viewport, but this'll do me nicely until I get time to learn some Houdini-UI skillz
Edited by howiem - March 17, 2020 09:07:13
Screenshot from 2020-03-17 13-02-04.png (178.1 KB)
Or if you feel like extending the HDK you can write a scene hook.
There is an example here:
$SHT/samples/DM/DM_SceneBoundsHook.C
But a python hook would make sense.
mabelzile
Is there an example of "nodeless python state that can run in multiple contexts."? I want to show some text over the viewport regardless of context, something like the cook time/FPS so that should allow at least using a larger font and offseted from one of the corners of the viewport.
Is this possible?
To setup a multi-context state you just need to pass an array of contexts to the ViewerStateTemplate [www.sidefx.com] constructor. You ca use a text drawable or resourceutils.HUD to draw text, both supports hou.drawableTextOrigin for placing the text.
Thanks for replying. But there is no way to query the corner of a viewport, right? I just have to hard code the position?
jerry7
This is cool! Any way to creat a line break though? I tried adding "\n" and even "\\n" and (GAD!) "\\\n" and no dice.
EDIT: Actually, putting the text in a python SOP with line breaks, then using this as a channel ref works. It's a bit ugly though.
Edited by mrCatfish - March 26, 2021 11:22:10
Sean Lewkiw
Machine FX - Cinesite MTL
animatrix_
There is no query API for that. hou.GeometryViewport.size() returns the viewport size (x,y,w,h) in UI space. You could use it to compute the corners but unfortunately there is a bug as the returned x,y origin is always 0,0... We have hou.GeometryViewport.viewerGeometry() in beta that returns the viewport geometry size (x,y,w,h) relative to the viewer origin in the UI space.
I put this together from the help but I can't get anything to show up at the obj level for example. I run the code using the Python SOP for testing first.
Am I missing something?
import hou
class State(object):
    def __init__(self, state_name, scene_viewer):
        self.state_name = state_name
        self.scene_viewer = scene_viewer
        # Create an empty text drawable
        self.text_drawable = hou.TextDrawable(self.scene_viewer, 'text_drawable_name')
        # Display the text on the next viewport redraw
        self.text_drawable.show(True)
    def onDraw( self, kwargs ):
        # draw the text in the viewport upper left
        handle = kwargs['draw_handle']
        (x,y,width,height) = self.scene_viewer.curViewport().size()
        margin = 100
        params = {
            'text': 'First line<br>Second line<br>Third line',
            'multi_line' : True,
            'color' : hou.Color(1.0,0.0,0.0),
            'translate' : hou.Vector3(0, height, 0),
            'origin' : hou.drawableTextOrigin.UpperLeft,
            'margins': hou.Vector2(margin, -margin) }
        self.text_drawable.draw( handle, params )
def createViewerStateTemplate():
    """ Mandatory entry point to create and return the viewer state
        template to register. """
    state_typename = "statedemo"
    state_label = "Statedemo"
    state_cat = hou.objNodeTypeCategory()
    template = hou.ViewerStateTemplate(state_typename, state_label, state_cat)
    template.bindFactory(State)
    template.bindIcon("MISC_python")
    return template
animatrix_
I don't think you can register the state from Python SOP. You still need either create a state from Viewer State Browser or just create a .py file in viewer_states directory (either in your package or $HFS/houdini). In this file you don't have to call createViewerStateTemplate() (I think this is just a method exposed for states factory)
couple of things:
1. "color" param is not supported for TextDrawable (should be "color1")
2. afaik you still need to enter the state (ie call somewhere toolutils.sceneViewer().setCurrentState("statedemo")). it's not like a permanent hook to inject additional drawables.
Thanks for replying. I thought it would be permanent, because I want me text to be visible in the viewport permanently like the FPS display.
If color is not supported the help file should be fixed
animatrix_
you are missing a call to registerViewerState in your code
e.g.
hou.ui.registerViewerState(createViewerStateTemplate())
And yes you need to enter the state to take effect.
You're right the text drawable example in the doc is wrongly using the color parameter
Edited by mabelzile - March 27, 2021 19:30:22
Thanks a lot! But a python state can always persists? Would another state override it?
In Python SOP I can not test this?
I tried your code:
It did register it but I didnt see any texts in the viewport.
Once a state is registered you have to activate it by entering the viewport (enter key) or call hou.SceneViewer.setCurrentState. The running state disappears as soon as you exit (Esc. key in the viewport or by calling hou.SceneViewer.setCurrentState, hou.SceneViewer.enterViewState, etc...). Your state remains registered until you call hou.ui.unregisterViewerState or exit Houdini.
Edited by mabelzile - March 28, 2021 10:20:07
mrCatfish
jerry7
You can just tick "multiline" on the vcomment parm.
mabelzile
howiem
Mabelzile, do you have any news regarding a viewport callback in python?
