Difference between work item attribute and environment vars?
1590 1 0-
- EricSheng
- 159 posts
- tpetrick
- 616 posts
The attributes created using the environment edit are exported to the environment of out of process jobs run by the scheduler. It adds the “export” flag onto the attributes. Generally that node is used if you have attribute values that you want to pass to some external program or shell script that's controlled by env vars.
