When I render with Karma, the TIF file is too bright, compared to the viewport?
How can I adjust the file output to match viewport?
ANSWER: For now, render to JPG. Karma renders JPG files using the 2.2 gamma.
[SOLVED]Karma Gamma?
3003 2 0-
- Enivob
- 2658 posts
- mark
- 2673 posts
When I render to TIF (or EXR), I get the same color space as when I render to the viewport (at least with mplay). Are you rendering to 8-bit TIF images or float?
In the Karma LOP, there's an OCIO image filter you can use to specify a color transform if you want to convert to a specific color space before saving to disk.
- Enivob
- 2658 posts
