I have a problem with a multiparm block (list) with a 2 float parameters and a nested Folder (simple). Without the nested Folder there are no issues, however when I attempt to save my .hda with the nested folder I get the following error in my Houdini Console:
ERROR: (-1): Syntax error: syntax error, unexpected $end, expecting '{'
It seems the multiparm is confused at this point. An instance count of 1 shows me 0 parameters (expected 2 and the folder). When I increase the instance count to 2 I suddenly get 3 float parameters (expected 4 + 2 folders).
I have another HDA (can't share) which show similar issues but is usable in Houdini. However, when using the HAPI to loop over the number of parameters in the multiparm I come across the nested folder twice, once with the correct name and another one with _0 post-fix (and empty LabelSH). This is a problem because the parmInfo.instanceCount does not account for this additional parameter.
I have attached my hda. I'm using 18.0.423. Is this not supported or should I change something somewhere?
Thanks,
Vin
