Exception in thread Thread-2
   3212   1   2
Sometimes it logs this during cooking:
Exception in thread Thread-2:
File “C:\Program Files\Side Effects Software\Houdini 18.0.391\python27\lib\threading.py”, line 801, in __bootstrap_inner
self.run()
File “C:/Program Files/Side Effects Software/Houdini 18.0.391/houdini/python2.7libs\houdinihelp\api.py”, line 593, in run
w.delete_by_term(“library_path”, kw)
File “C:/Program Files/Side Effects Software/Houdini 18.0.391/houdini/python2.7libs\whoosh\writing.py”, line 210, in __exit__
self.commit()
File “C:/Program Files/Side Effects Software/Houdini 18.0.391/houdini/python2.7libs\whoosh\writing.py”, line 930, in commit
self._close_segment()
File “C:/Program Files/Side Effects Software/Houdini 18.0.391/houdini/python2.7libs\whoosh\writing.py”, line 843, in _close_segment
self.perdocwriter.close()
File “C:/Program Files/Side Effects Software/Houdini 18.0.391/houdini/python2.7libs\whoosh\codec\whoosh3.py”, line 267, in close
self._cols.save_as_files(self._storage, self._column_filename)
File “C:/Program Files/Side Effects Software/Houdini 18.0.391/houdini/python2.7libs\whoosh\filedb\compound.py”, line 297, in save_as_files
for name, blocks in self._readback():
File “C:/Program Files/Side Effects Software/Houdini 18.0.391/houdini/python2.7libs\whoosh\filedb\compound.py”, line 279, in _readback
self._tempstorage.delete_file(self._tempname)
File “C:/Program Files/Side Effects Software/Houdini 18.0.391/houdini/python2.7libs\whoosh\filedb\filestore.py”, line 544, in delete_file
os.remove(self._fpath(name))
WindowsError: : ‘C:\\Users\\user\\Documents\\houdini18.0\\config\\Help\\index2.7\\MAIN.tmp\\ufmca3s6wvb5hopg4enxsx3wqqhb.ctmp’
But Houdini is not crashed and the result is right.
Thanks for reporting that, it's a bug that's not related to TOPs and should be harmless. I've logged it on our side.
