Log not found
   2923   5   1
Hi, I am trying to figure out why I get “log not found” when I got erros on PDG? Any tips?
https://vimeo.com/user2163076 [vimeo.com]
What node is this for? Any work items that cook in-process will not produce a log file, and will show that message in the MMB panel. Any prints will usually go to your console in that case.
chrisgreb
Thanks for the feedback!
I am having issues fetching some nodes and I can't figure out what is happening because it is not showing any log or error messages in the bottom like it used to I think it is an issue in my local machine, any tips?
If you right click on the scheduler node you can choose “Open Temp Directory”. This should open a file explorer at the directory that contains log files. If there are any they will be in a sub directory like: 12345/logs/ropfetch1_1.log
Nice! So why does it say that log is not found?
Thanks.
Maybe it's a bug - what version of Houdini and platform are you on?
