33708: Fatal error: Segmentation fault
   3091   2   0
I'm using Houdini apprentice, and I'm just using regular SOP nodes to adjust the bevel/height/width of lines with polywire…
And it's crashing every time I make an adjustment, saying there's a 33708: Fatal error: Segmentation fault
Does anyone know why this may be? It happens even when going up the node network to just adjust Uniform Scale, something as simple as that!
OK - so it seems to specifically be happening now when I'm using a group to determine what edges to bevel… What the heck!
Edited by KZLCR - May 24, 2020 16:01:22
Your hardware may be bad. Check the system requirements under the Support menu at the top of the page.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Enivob
If by bad you mean outdated, not possible. If you mean faulty, I've checked it out, seems fine… SideFX said maybe it's because I had spaces in the file names, I've yet to check it out.
i9-9900k
64 gb 3200 ddr4
rtx 2080 super
970 evo plus
Edited by KZLCR - May 27, 2020 16:16:26
