list of list of integers (VEX)
   4128   5   0
Hi all,
I've been trying this now for two hours without success.
I'd like to create “list of lists of integers” in VEX. I need to access each pair again later on by index.
In python:
mylist = [, , ]
mylist –>
I cannot figure out how to create the elements, as int, vector2, array().
Any help would be appreciated. Thank you!
m.
disclaimer: NOT a VEX expert, just reading the help,
Note
Currently VEX does not support multi-dimensional arrays.
so maybe that's why ?
it works for vector as in:
vector mylist[] = { {1,0,0}, {0,1,0}, {1,1,0} };
so maybe do this and ignore the last component ?
last word, dunno.
hmm…this seems to work:
vector mylist[] = array( {0,0}, {1,0}, {0,1}, {1,1} );
I still don't know $4it tho.
Can you store it as a flat integer array, and an array of offsets?
thanks for the inputs, much appreciated.
VEX not yet supporting multi-dimensional arrays is one of those key points, I missed this information…
Well I can use vectors as a hack and then cast the 3 floats to int, I just was searching for a ‘native’ solution.
Thanks again, I believe this should work!
m.
I'd go for flat integer array too, rather than array of vectors that you need to convert
