I'm having some issues rendering a crowd sequence with Mantra. Basically what's happening is whenever I render a frame range, for some reason the crowd renders completely static (see first link). Camera movement and everything else seems to render correctly.
I have the simulation cached, and the flipbook works as intended (see second link). Textures also seem to render correctly.
Now, what's really odd to me is that if I switch to render current frame (on the same Mantra node), set the playhead on the timeline to any frame and render to disk, that frame renders correctly.
Am I missing anything of importance here here? Just thought I'd check here before I set everything up again in a clean scene for a second attempt.
I'm on 18.0.499.
Gifs with no setting changes between recording them:
Incorrect render: https://imgur.com/a/ncFMFbs [imgur.com] (short, but you see the problem)
Correct flipbook: https://imgur.com/yvmT8FR [imgur.com]
Appreciate any help on the matter.
Cheers!
Mantra not rendering crowd animation correctly
721 0 0- frig2
- 11 posts
