Tops RBD cache wedging after 18.0.416 releases working ?
   3327   1   1
below is 416 and 597 results. and hip file
worked the sim in 287 and 416 versions.
460 499 566 596 597 kept giving unmatched tops wedge results
please try this file and see if it works in other than 416 and 287 for you, and update here if its working or not working.
we can get know if it is my machine error or software error.
hover over network editor and press 1 to go into tops network and go to right click the selected node context menu and hit the selected last node's cook selected node.
thank you for your time and help.
416.mp4 (109.0 KB)
597.mp4 (51.7 KB)
PDG_RBD.416.hipnc (1.6 MB)
Houdini Fx Artist (Build)
switching to the Constraint Network DOP's expression for the Overwrite with SOP parameter to $SF == 1, fixed,
since the source SOP is getting marked as time dependent when running under PDG.
