I want to set all the values of all parameters of all nodes in all contexts to the current value (at a specific frame). So, everything that is time dependent is effectively frozen or locked in at a certain value.
Sounds simple but there are a lot of edge cases like expressions evaluating scripts, referencing other nodes from perhaps other networks, hidden parms, unusual types, animated channels, etc.
Is there a beautiful and simple way that I'm missing?
How do I hard-set all parameters to the current value?
1762 3 2-
- Soothsayer
- 875 posts
- shadesoforange
- 203 posts
Essentially you want to call hou.Parm.deleteAllKeyframes() [www.sidefx.com] (this includes hscript expressions, hscript, python parms) etc and you'll be left with the current value.
Pseudo python code incoming:
Hope that helps
Edit: If you want to do it at a specific frame, you can set the current frame to a specific value first.
for network in network: for node in network.nodes(): # there might be a function to get all node instances of all networks right away for parm in node.parms() parm.deleteAllKeyframes()
Hope that helps
Edited by shadesoforange - Oct. 17, 2020 17:32:24
Manuel Köster - Senior Technical Artist @Remedy Entertainment
https://www.remedygames.com/ [www.remedygames.com]
http://shadesoforange.de/ [shadesoforange.de]
https://twitter.com/ShadesOfOrange_ [twitter.com]
- Soothsayer
- 875 posts
I use the deleteAllKeyframes() but it doesn't work for all parm cases. I think there are two problems with it. It doesn't deal with scripted parms well (think multiline python code) and I there seem problems with evaluating the parms in the right order, especially if there are deep dependencies.
The best I could do so far is to use deleteAllKeyframes() but copy all values first into a dictionary that I later read the values from. Second, I just ignore the parms with multiline code as they mostly seem to be irrelevant in my case. There's one parm that gets set in a script and I just sort of rewrite it a little but ideally I'd like to have a way to just freeze its current value.
Jobless
Jobless
- shadesoforange
- 203 posts
Could you describe situations where this fails? I have couple of scripts that do shenanigans similar to this and would like to hear about potential pitfalls.
Scripted parms (python SOP/wrangle) are “just” be string parameters with language highlighting (AFAIK).
And in my head the order shouldn't matter if you don't have parameters that query if another parameter is an expression.
