Point deform with falloff?
   3225   3   0
Hi guys,
I cut out part of a character to do some simulation work on it.
But when I try to point deform that upper torso to the original full body the lower half freaks out.
Is there a way to paint a mask where I want the point deform to affect?
Thanks.
Sort of, but you'll have to build the rig yourself. Feed the point deformed geo and the original with the mask into a point wrangle/point vop and use a lerp function or mix node with the mask controlling the blend between the two input's position values.
I'll try this tonight, hopefully it works. Will post an update.
jsmack
This worked! Thank you!
