Hello there!
I'm creating a camera rig tool that I want to activate from a python shelf tool.
I've run into an issue with setParms where I'm trying to set the parameter of a transform node to have an expression.
I either get a syntax error or “Cannot set a numeric parm to a non-numeric value”
ch(“../../Controller/tx”) is the expression I want to insert. The errors only occur when I add the setParms line. setParms has been working for all of the other nodes in my code.
Version 1
Rig = obj.createNode(“geo”, node_name = “Camera_Jib”)
j_transform_01 = Rig.createNode(“xform”, node_name = “j_transform_01”)
j_transform_01.setParms({“tx”: ('ch(“../../Controller/tx”)')})
Version 2
j_transform_01.setParms({“tx”“ch(”../../Controller/tx“)”)})
Sorry if this is a simple fix, I'm quite new to Python.
Thanks! :-)
