Hello, I am trying to use a handle that I created by the following method in the documentation:
“A Handle can be exposed on your asset by selecting Export Handle To Digital Asset from the Popup menu on the handle you wish to export in the viewport. The Type Properties window must be open when you do this. This operation will automatically set up the new Handle and add the necessary parameters.”
And further the documentation says:
“In Unity, make sure that Enable Handles checkbox in the ASSET OPTIONS section is enabled.”
I am not seeing that checkbox
I am using Houdini Indie 18.0.460 and Unity 2020.1.11f1
Any help would be appreciated.
Bill
Not seeing "enable handles" in Asset Options
1500 0 1- Billd
- 2 posts
