Hi all, I have a script that can do some cooking and timing in Houdini. However, right now I can only run it in UI mode. Is it possible to run my script using the Houdini command line? Something like:
hython “somefile.hip” -script “somescript.py”
Basically, I'm trying to find a way to get hython/houdini to run a script after loading a file, all automated.
Passing a script into HYTHON?
5520 2 0-
- easythrees
- 12 posts
- doctorbob
- 30 posts
in some cases, it might work to make your script be responsible for loading the hip file with a wrapper function. generally how we do things here for farm export stuff.
eg
and if your python script is structured thusly:
cheers,
chrisg
eg
/path/to/hython /path/to/script.py -i /path/to/hip.hip
from optparse import OptionParser def do_the_thing(): # do amazing things here pass if __name__ == "__main__": # this gets run when called via the commandline # parse commandline arguments here and pass to the main function parser = OptionParser(usage) parser.add_option("-i", "--hip", dest="hipfile", help="path to .hip file") # load the scene hou.hipFile.load(options.hipfile) # now do the thing with the scene do_the_thing()
cheers,
chrisg
- easythrees
- 12 posts
