HDA causing "Operator save failed" on scene save.
   1788   1   1
Hi
I'm dealing with a custom HDA that is currently corrupting scene files by interrupting the save process, throwing the error "Operator save failed", so that when the file is opened again, only a couple of nodes load and it throws the Error: "Was expecting(Asset1.parm) in parameter file. Invalid .hip file header".
Has anyone faced similar problem or has a clue of what could be the cause of the save error?
Cheers
Hi
Is there a solution ? I'm facing the same issue.
Paul
