Just a quick question about grouping.
I have a number of seperate cubes that I separate using a connectivity sop, and then a partition sop. This gives me a group for each cube using the rule cube_$CLASS.
Now what i need to do is essentially group the groups using an animated bounding box. However, when I use the second group node with the bounding box, the faces of each cube gets put into this group individually. I need it so that each whole cube gets placed into the group and not just their faces.
Can anyone help???
grouping question
3909 5 2- jimbob8s
- 34 posts
- Simon
- 2199 posts
Group by points inside the bounding box then use another group sop to expand the group and convert it to a primitive group.
You can expand a group using the edges option - edge depth - just turn it up to about 4 that should get all the points in each cube.
- jimbob8s
- 34 posts
- Simon
- 2199 posts
- jimbob8s
- 34 posts
- jimbob8s
- 34 posts
