I used to use the old Curve tool to place points for manual placement of source points for the Copy to Points SOP, because it had the "Points" option. The new Curve tool is missing this option to draw individual points without primitives.
I know, i can just draw curves and use the Add SOP to delete the Primitive afterwards, but when placing the points, the actual curve makes the scene more difficult to navigate during point placement.
Is there another way to place individual points quickly in Houdini 19?
Ivan
H19 curve tool
1409 3 1- ivanmalek
- 143 posts
- CYTE
- 679 posts
- sekow
- 238 posts
- ivanmalek
- 143 posts
CYTE
Hey ivanmalek,
to get the old curve tool, you have to enable Asset Definition Toolbar in the Asset Manager.
Then you can switch between old and new curve sop directly on the node parameters tab.
Cheers
CYTE
Thanks, this does help.
Unluckily, the Add SOP doesn´t seem to support the same click-to-place point functionality as the curve tool.
