COPs get the dominant colors of an image.
   4300   12   0
There's Quantize COP but I don't want to divide the existing pixels by predefined ranges, instead I would like to extract the dominant colors of an image like Kuler (Adobe Color) does:
Or when a Color Table is generated from an image in Photshop:
Or ImageMagik -colors x:
But I'm unsure about how to go about this. I can see the histogram in the Composite View, but not sure how would I cluster them and sort by occurence:
Am I missing some straight forward way to do this?
prb
Edited by probiner - Dec. 16, 2021 19:32:11
Hi Probiner,
not sure whether this is acceptable for your workflow but I have used the cluster point SOP for this.
Edited by Konstantin Magnus - Dec. 17, 2021 08:45:00
cluster_colors.hiplc (564.1 KB)
Konstantin Magnus
Hi Probiner,
Thanks. I've looked into and I'm noticing that while it does an interesting job at posterizing, the issue I notice with a lot of solutions is that once you lower the amount of "buckets" is when you start to see some issues:
I would expect blue to be dominant while reducing the number of clusters but seems that red gets the cake.
With Adobe Color I also don't get the "importance" of each swatch.
I've been using Attribute Promote Median or Mode but I was looking for something that would offer a more "statistical analysis approach", eheh...
Edited by probiner - Dec. 16, 2021 21:24:24
maybe you calculate some attributes for each cluster and use these attributes to sort the clusters. You can take for example the deviation on a cluster. If this value is low, the colors are close together. If you decrease the number of clusters, this value will probably raise and gives less good approximation. Here is an example (modification of Konstantins file).
cluster_colors_measure_clusters.hipnc (581.0 KB)
Ok, I assume you have already checked the fuse SOP then.
Edited by Konstantin Magnus - Dec. 17, 2021 08:45:31
fuse_colors_2.hipnc (1.7 MB)
Aizatulin
Interesting addition! It's actually interesting to look at the "streaks" of color when you do @P = @Cd ; and you can almost see the clusters very clearly then. Thanks for the file!
Konstantin Magnus
I didn't and you're very right, I should have tried, ehehe That looks great, really. I guess it didn't come to mind because one will not set the amount of buckets but a Threshold. Thanks for the file!
Cheers
prb
probiner
Aizatulin
Konstantin Magnus
Cheers
prb
Something to try would be doing the snapping in a different color space, rather than linear rgb. Maybe try Lab or Y'uv?
jsmack
probiner
Aizatulin
Konstantin Magnus
Cheers
prb
Yeah I did try that, although I didn't try with snapping since the values in other spaces can be very wild, so I retook Magnus setup with the clustering and tried a few color spaces with the function ctransform() in VEX. I've found HSV one is broken, so I already reported the bug.
Scene attached for example. I liked the results I got with Lab and hsl on my images.
Still not COPs, but hey..
Cheers
prb
Edited by probiner - Dec. 17, 2021 14:55:54
PRB_ctransform.hipnc (1.7 MB)
If you absolutely need COPs, I read numpy does clustering, too.
Btw. I found fusing and Lab to be alright.
fuse_colors_Lab.hipnc.zip (2.5 MB)
Konstantin Magnus
Yeah looks very nice. I guess I can give fuse another try, but the reason I'm shying away from it is that I can't define the amount of clusters.
Thank you everyone for all the ideas!
prb
The nearpoint()-function can also be used to index colors ie. based on a reference image.
Edited by Konstantin Magnus - Dec. 19, 2021 10:34:34
color_posterization.hiplc (181.0 KB)
Konstantin Magnus
Effect looks stylish but it does deviate from the original colors.
Also nice bit about using directly an URL for the Attribute from map
Cheers
prb
