Karma Motion Blur way to strong / weird
4771 7 0-
- chf
- 186 posts
I am rendering an old project which used to use redshift with Karma.
I have a simple rbd sim and then transform hires onto the proxies including velocity from the sim.
Karma just messes up the motion blur. Is this a (current) limitation or a bug?
The 4 images are:
no motion blur CPU
no motion blur XPU
with motion blur CPU
with motion blur XPU
lighting looks different, but thats something I can work
the big problem in both is the weird looking motion blur
The 4 images are:
no motion blur CPU
no motion blur XPU
Edited by chf - Jan. 13, 2022 06:09:33
- Enivob
- 2658 posts
- chf
- 186 posts
it seems to be related to them being packed primitives and also the fact that I am randomly deleting those packed points through the sequence, which leads to point numbers flipping around and karma seems to be confused by that
after i used an unpack node it it worked fine, but way slower of course
also for some reason motion blur on packed just completely fails to render, just wont any more
I guess this may be some bug / graphics driver issue because optix also failed and then crashed
KarmaXPU: device Type:Optix ID:0 has registered a critical error , so will now stop functioning. Future error messages will be suppressed
will test further
will test further
Edited by chf - Jan. 13, 2022 11:05:19
- mark
- 2676 posts
- chf
- 186 posts
mark
It almost looks like the topology might be changing frame to frame. Are you using velocity blur?
I am using velocity blur. But it doesn't work on packed primitives.
Made a quick setup to sandbox the issue.
No matter what I do, Motion blur only works if I unpack the transformed geometry before importing it into solaris/karma world.
- mark
- 2676 posts
chfUsd expects the velocity primvar to be named
velocities. If you stick an Attribute Rename SOP before /obj/karma_test/output0, the instance will pick up velocity properly and you should see motion blur. This is not obvious at all. It took a bit of debugging on my end to actually track this down.The other thing which I see you attempted was to use "Unpack" in
/stage/sopimport1. This uncovered a bug in Karma. This should be fixed in tomorrow's daily build. So leaving the vattribute alone, but choosing Unpack in the SOP import should work in tomorrow's build.
- tamte
- 9415 posts
mark
Usd expects the velocity primvar to be named velocities. If you stick an Attribute Rename SOP before /obj/karma_test/output0, the instance will pick up velocity properly and you should see motion blur. This is not obvious at all. It took a bit of debugging on my end to actually track this down.
does it support angular velocities?
since those are important on packed primitives
I tried renaming w to angularVelocities, not sure if that's correct property on regular prims, but also didn't seem to do anything
- chf
- 186 posts
markchfUsd expects the velocity primvar to be named
No matter what I do, Motion blur only works if I unpack the transformed geometry before importing it into solaris/karma world.velocities. If you stick an Attribute Rename SOP before/obj/karma_test/output0, the instance will pick up velocity properly and you should see motion blur. This is not obvious at all. It took a bit of debugging on my end to actually track this down.
The other thing which I see you attempted was to use "Unpack" in/stage/sopimport1. This uncovered a bug in Karma. This should be fixed in tomorrow's daily build. So leaving thevattribute alone, but choosing Unpack in the SOP import should work in tomorrow's build.
that's fantastic thank you so much!
