When I render with Karma output is spamming about Redshift
   5073   7   3
When I render with Karma every frame spams about Redshift Render
But I do not even use Redshift in this scene.
Redshift for Houdini plugin version 3.0.63 (Jan 18 2022 18:20:57)
Plugin compile time HDK version: 19.0.498
Houdini host version: 19.0.498
Plugin dso/dll and config path: C:/ProgramData/Redshift/Plugins/Houdini/19.0.498/dso
Core data path: C:\ProgramData\Redshift
Local data path: C:\ProgramData\Redshift
Procedurals path: C:\ProgramData\Redshift\Procedurals
Preferences file path: C:\ProgramData\Redshift\preferences.xml
License path: C:\ProgramData\Redshift
Cheers
I'm seeing the same thing. I've been ignoring it, though I'm wondering if it affects load times - must do at least a little. Removing the env-vars that load RS seem to be the only obvious solution. For me I'm rendering with both so just living with it.
“First things first – but not necessarily in that order”
– The Doctor
Yeah same, also spams console on file->new with redshift stuff if I've been in lops.
Yea, ok, it is not great. I get the feeling that this may slow things down. I think I will try to remove Redshift and see if it becomes any faster.
Hey guys, did anyone find any solutions to this aside from not loading Redshfit - we're having the same problem.
The attached error report is from using Karma. No RS specific nodes anywhere in the scene.
Will
Screenshot 2022-11-23 110211.png (324.3 KB)
The redshift plug-in loading and licensing adds about 25 seconds to each frame I render with karma. When your frame is 2 seconds and the redshift crap is 25 it kinda ruins the party. I am keen for any ideas or workarounds.
Edited by IsStuff - March 14, 2023 10:25:37
Robert Kelly
Any update on this? Having same issue seems to be slowing down the render
Hello!
Could you try to post this on the Redshift Forum? I Don't think that the RS dev will check the reports here.
https://redshift.maxon.net/category/38/bugs-solaris-hydra [redshift.maxon.net]
I'm wondering if this problem can be related to this thread also:
https://redshift.maxon.net/topic/46764/lag-opening-a-file-maybe-related-to-rs/8 [redshift.maxon.net]
You might try to rename the cpu dll too.
Cheers!
