I'm currently trying to make our Karma nodes read the current cameras abc resolution (maya export) instead of manually setting render resolutions on the Karma node. In SOP level days i would just read from an alembic archive and use ROPs to read the res fromt the camera, which was very handy. At the moment Im not quite sure what the idea/workflow in Karma would be to not manually needing to set the resolutions. On the scene Graph Details I can only find h and l Aperture, no info about the res thoguh. Is there maybe a way to python query the resolution? I'm a bit lost here ^^
Thanks a mil and best regards
Extracting alembic cam resolution
1037 0 1- kernberg
- 13 posts
