Basic detail function not working... how?! SOLVED
   2163   3   0
Hi
I've used this function about a hundred times (but maybe I'm crazy) and its not working in my scene. I've got 2 detail wrangles:
top one (named "source"):
f@value = 8.0;
bottom one (named "fetch_float"):
f@testValue = detail("../source/", "value", 0)
...but the bottom wrangle gets the value 0 instead of 8. isn't this suposed to work?
Edited by olivierth - July 12, 2022 16:30:43
Using "op:" before your node paths works.
f@testValue = detail("op:../source/", "value");
olivierth
attribute functions in VEX can't reference other nodes, only read from files. The first argument is a path to a file on disk. Houdini can read from nodes as if they are virtual files by prefixing the node's path with op: as @gorrod suggests.
Thanks a lot! I'm so surprised I never ran into this probleme before!!
-Olivier
