Embedding Extra Files into HDA directly from SOPs
918
2
1
Lucca
Aug. 9, 2022 12:03 p.m.
is there a possibility to add an extra file to an hda directly from sops context, so without first saving a bgeo and then adding it manually to the extra files tab from the HDA?
Greetings Lucca
Edited by Lucca - Aug. 9, 2022 12:04:19
N-G
Aug. 9, 2022 1:11 p.m.
Did you use stash node to store a geometry inside your node network? You can also freeze geometry as well.
Lucca
Aug. 10, 2022 5:13 a.m.
N-G Did you use stash node to store a geometry inside your node network? You can also freeze geometry as well.Oh yeah stash should work.Haven't thought of that. Thanks
