primitive properties lookat
   1165   3   2
How do you point primitives towards another object?
I've tried with primitive properties look at and my badly formed vex.
Sorry I'm sure that I am missing the obvious.
Edited by GrahamDClark - Dec. 12, 2022 16:47:34
Prims_lookAt_point_fail_GDC.hipnc (144.7 KB)
Here's one way to do it. I'm using dihedral() in a prim wrangle to compute the matrix that would rotate each primitive's normal to face the vector you want. I'm also binding the center of each primitive to a temporary attribute... this is because when you multiply a point by a 3x3 matrix, you need to make sure the center of rotation is at the origin. Once that's done, I promote the attributes to points, then use a point wrangle to move each primitive's points so that the center is at the origin, multiply by the calculated matrix, then move back to the original pivot position.
Prims_lookAt_point_fail_GDC_toadstorm.hipnc (152.9 KB)
Awesome, always loved your site and MOPs.
I changed one part so the prims faced the target more and the geo could be moved.
//vector target = normalize(point(1, "P", 0));
vector p0 = point(1,'P',0);
vector target =normalize(p0-@P);
Thank you again, hours of pain lifted.
Edited by GrahamDClark - Dec. 12, 2022 18:21:01
Prims_lookAt_point_fail_GDC2_toadstorm.hipnc (153.3 KB)
Oh right, duh. Forgot to include @P in the target vector. Thanks for catching that!
