is there possible to grab elements attrib to array?
   1830   4   1
is there possible to grab elements attrib to array without any loop in VEX?
say if i’m running a vex snippet in detail mode. I want to get a sorted P.y attrs into an array
Since houdini 19, Attribute Promote Sop has implemented a useful "array of all" method. Which is faster than using setdetailattrib() vex function. Since you want to store @P.y, you should first create a dummy attribute 'Py' as typing directly @P.y in Attrib Promote won't work.
This will just get the values into an array, sorted by point order.
To sort them by value, you could use the sort() function.
Check also the argsort(), which returns the list of indices sorted by the their values.
Note: these functions can be very cpu intensive.
goolyuyi
VEX can't, Python can:
node = hou.pwd()
geo = node.geometry()
py = sorted(geo.pointFloatAttribValues("P")[1::3])
https://www.sidefx.com/docs/houdini/hom/hou/Geometry.html [www.sidefx.com]
Andr
it make sense, thanks!
Andr
Instead you could use Sort Sop in "by attribute" mode. Which it seems to lead to significant speed boost over vex-only methods (like 10x faster with 100k points).
I attach an example .hip file with the various options I came up.
Edited by Andr - Dec. 17, 2022 10:11:38
promote_to_sorted_array.hiplc (109.8 KB)
