Python question...
I'm using hou.Node.loadItemsFromFile() and although it works fine, it does not seem return any objects. The items are selected after the load, but I think other items which were selected prior to the load remain selected as well.
What is the best way to get a handle on the nodes loaded by loadItemsFromFile()?
And... any chance there is an RFE already in place for augmenting this method to provide a return?
Python: Getting items loaded via loadItemsFromFile()
933 2 1- Tim Crowson
- 240 posts
- graham
- 1914 posts
A proper return value from loadItemsFromFile() would be ideal (not sure if there's an RFE for that or not) but as you mention you can get at the things you want by using the fact that Houdini will add the loaded items to the list of selected items as long as you just clear them first:
hou.clearAllSelected() my_node.loadItemsFromFile("/some/path.cpio") loaded_items = hou.selectedItems()
Edited by graham - Jan. 5, 2023 14:15:19
- Tim Crowson
- 240 posts
