Set string attribute from another geometry
   1818   2   0
Hi guys, newbie is here. I have a point geometry (csv table imported by Table Import) which have an integer and string attributes. I try to set these attributes to Curve points by Attribute Create node. I succeed with integer attribute using point("../tableimport1/",$PT,"data",0) expresion in value, but when I try to repeat it with string attribute it fails.
Have anyone some ideas how to success with it?
There is a companion function to point for accessing strings. It's called points. Try that instead. Check the help card, it only requires three parameters.
https://www.sidefx.com/docs/houdini/expressions/points.html [www.sidefx.com]
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
if you are copying just between corresponding point numbers as it seems to be the case
you should be able to just use Attribute Copy SOP
Edited by tamte - May 5, 2023 14:32:58
