Ello, I'd like to make a "master control" node (e.g. subnet with exposed parameters) which is referenced in different geometry contexts. I know I can right click and create a "reference copy" of a node, but it links all the parameters relatively which means I cant copy them to other locations. Is there a way to create an absolute reference copy of a node? This is the workflow I'm hoping for at the moment since I have a lot of parameters and in the different contexts I will need to override(remove reference) different parameters.
After writing all that I realized I'm basically describing an HDA, but maybe this approach could have its own use cases. I've always wondered what's a good way to reference a bunch of parameters, the only 2 techniques I'm aware of for now are individually copy pasting references or making a an entire node a reference copy. And another method is dragging them to the Parameter Interface window, I haven't explored that workflow much yet.
How to create an Absolute Reference Copy of a node
1071 2 0- NNNenov
- 36 posts
- Benyee
- 56 posts
I'm not sure if there are some new approaches in the newer Houdini versions
can achieve the function you mentioned.
This is a script I wrote before that can do batch conversion from relative refs to absolute ones.
You can try it as a python shelf tool.
import string def abs_path_reference(node): parms = node.parms() #filter string type parameters refParms = [] for i in parms: if ( (i.rawValue().find('ch("../') != -1) or (i.rawValue().find('chs("../') != -1) ): refParms.append(i) print(str( len(refParms) ) + " parameters channel referenced and modified to:") #loop for finding out node(s) which channels reference from for parm in refParms: orig_expr=parm.rawValue() absPathStrs=[] relPathStrs=[] for i in parm.rawValue().split('('): for j in i.split(')'): if j.find('../')!=-1: tmp1=j.split('/') tmp1.pop() tmp2='/'.join(tmp1) relNodePath=tmp2[1:len(tmp2)] refNode=node.node(relNodePath) absNodePath=refNode.path() absPathStrs.append(absNodePath) relPathStrs.append(relNodePath) #setting new expressions new_expr=orig_expr for index in range(len(relPathStrs)): count=new_expr.count(relPathStrs[index]) new_expr=new_expr.replace(relPathStrs[index],absPathStrs[index],count) print(new_expr) parm.setExpression(new_expr) print("-------------------------------------------") #excute script sels = hou.selectedNodes() for sel in sels: abs_path_reference(sel)
Edited by Benyee - June 22, 2023 08:53:32
- NNNenov
- 36 posts
Benyee
You can try it as a python shelf tool.import string def abs_path_reference(node): parms = node.parms() #filter string type parameters refParms = [] for i in parms: if ( (i.rawValue().find('ch("../') != -1) or (i.rawValue().find('chs("../') != -1) ): refParms.append(i) print(str( len(refParms) ) + " parameters channel referenced and modified to:") #loop for finding out node(s) which channels reference from for parm in refParms: orig_expr=parm.rawValue() absPathStrs=[] relPathStrs=[] for i in parm.rawValue().split('('): for j in i.split(')'): if j.find('../')!=-1: tmp1=j.split('/') tmp1.pop() tmp2='/'.join(tmp1) relNodePath=tmp2[1:len(tmp2)] refNode=node.node(relNodePath) absNodePath=refNode.path() absPathStrs.append(absNodePath) relPathStrs.append(relNodePath) #setting new expressions new_expr=orig_expr for index in range(len(relPathStrs)): count=new_expr.count(relPathStrs[index]) new_expr=new_expr.replace(relPathStrs[index],absPathStrs[index],count) print(new_expr) parm.setExpression(new_expr) print("-------------------------------------------") #excute script sels = hou.selectedNodes() for sel in sels: abs_path_reference(sel)
Fascinating, thank you for sharing, I haven't made a shelf tool before or messed with python in houdini (although I used it quite a bit in C4D), but it looks well worth investigating.
