Been a while since I've set up Kinefx HDAs, but I remember just laying down a compute rig pose node inside an HDA and setting the default state of the HDA to "kinefx__rigpose" and promoting the parameters on the compute rig pose node. That would give me the ability to select joints and have the transform parms show up on the HDA.
But in 19.5 when I lay down the compute rig pose node and promote parameters, I get the following error:
File "kinefx::Sop/computerigpose/promoteparms", line 2, in <module>
File "/Applications/Houdini/Houdini19.5.640/Frameworks/Houdini.framework/Versions/19.5/Resources/packages/kinefx/python3.9libs/kinefx/poseparms.py", line 1207, in promoteComputeRigPoseParms
appendPoseParms(t_node, save_to_definition, parmname)
File "/Applications/Houdini/Houdini19.5.640/Frameworks/Houdini.framework/Versions/19.5/Resources/packages/kinefx/python3.9libs/kinefx/poseparms.py", line 1200, in appendPoseParms
node.setParmTemplateGroup(ptg)
File "/Applications/Houdini/Houdini19.5.640/Frameworks/Houdini.framework/Versions/19.5/Resources/houdini/python3.9libs/hou.py", line 15802, in setParmTemplateGroup
return _hou.Node_setParmTemplateGroup(self, parm_template_group, rename_conflicting_parms)
hou.OperationFailed: The attempted operation failed.
Parameter name 'enable#' is invalid or already exists
Any ideas. I'm probably forgetting something simple.
Compute rig pose errors
689 2 0- made-by-geoff
- 63 posts
- made-by-geoff
- 63 posts
- ernalberry
- 1 posts
