Camera metadata in Karma render
   3865   10   1
Hi all,
Experimenting with XPU for production and was curious if anyone has found a way to bake in camera metadata and extract it in Nuke for compositing. We are traditionally a V-Ray house and V-Ray bakes in metadata that allows you to recreate the CG camera in Nuke. This is extremely handy because it cuts out the need to export an .abc/.usd/.fbx camera for each shot and is just self contained inside of the image sequence.
- Tom
I thought the view matrix was baked in as metadata. Maybe that's just a mantra thing.
It's possible to add custom metadata that will be added to the exr, as long you use the improved exr driver.
I can try to make something with the python lop node when I have time and post here. Would be great to have this.
Heileif
That would be fantastic - definitely something we love about V-Ray is the built in functionality of this. Very useful indeed.
It should already be there by default
WorldToCamera
and
WorldToNDC
edit:
But I guess you want the camera metadata such as f-stop/lens/filmback size/shutter length
edit 2:
What about just embedding the camera as a camera.usda?
Edited by AslakKS - Nov. 16, 2023 21:04:34
There's a tutorial for adding arbitrary metadata to your exr outputs, check this out (note: you need to read the very bottom of the page, where it says "19.5 upgrade"):
https://noahhaehnel.com/blog/custom-metadata-in-solaris/ [noahhaehnel.com]
Martin Winkler
AslakKS
WorldToCamera
and
WorldToNDC
edit:
edit 2:
Thanks guys! I'll look into this. Kicking the camera out as a USD would also work, having it as part of the EXR is nice to cut down on separate files but it would be easy enough to automatically load in the camera into a nuke script when you bring in the latest render.
tomteller
How are you getting the camera into solaris? Can you import the same file into nuke, or was it created in Houdini?
Sometimes it’s an abc from Maya but we are doing cameras more frequently directly in Houdini.
Could you upload a V-Ray exr example, with the camera metadata?
Sure thing, please see attached (contains full passes + camera metadata). This is the script that we use in Nuke to extract the camera. https://gist.github.com/kpprt/cb07c3c196c5f4937bde6760b483dc82 [gist.github.com]
maelstrom_test_32_boat.0133.exr (8.8 MB)
