Get selected channel in graph with Python
   1420   2   2
Hi, everyone!
after a long day of struggling I have reached a wall and looking for help. I need to get a name of parm of selected channel with Python, but had no luck with that.
Maybe someone is familiar with ChannelGraph [www.sidefx.com] class?
Strangely a simple example with keyframes in Houdini's help, doesn't work either:
import hou
channel_editor = hou.ui.paneTabOfType(hou.paneTabType.ChannelEditor)
keyframes = channel_editor.graph().selectedKeyframes()
for parm in keyframes.keys():
    for key in keyframes[parm]:
        key.setValue(2 * key.value())
        parm.setKeyframe(key)
Hi, I just tried that snippet and it seems to work fine for me, and I'm able to get the name of the parm with
parm.name()
Do you now which part is failing? Is the keyframes.keys() dictionary empty?
Just to double check, you're trying to get the name of a channel for which you've selected keys in the graph itself, right? If it's just selected in the channel list you can instead do something like:
import hou
channel_list = hou.playbar.channelList()
for parm in channel_list.parms():
    if channel_list.isSelected(parm):
        parm.name()
Edited by michaelf - Nov. 23, 2023 11:57:34
Hi, michaelf,
correct, I am getting just an empty dictionary in keyframes variable "dict_keys()". Still have no idea, why it doesn't work for me. Your suggestion to use hou.playbar.channelList() works great for my case. Many thanks!!!
