merge file from python script node
   2257   2   0
Hi there
I d like to merge a file from python script node
the code looks like that
in empty scene
in stage/
create Python script node
asset_file_name = "D:/file.hip"
hou.hipFile.merge(asset_file_name, node_pattern="*", overwrite_on_conflict=False, ignore_load_warnings=False)
mergedNode = hou.node("/stage/file_Node_USD")
mergedNode.parm("File").set("D:/File_USD.usd" )
if I run the script from shelf it works
but if I put the script inside a Python _script Node in the /stage
comes an error:
Error
Python error: Traceback (most recent call last):
File "<stdin>", line 7, in <module>
File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.640/houdini/python3.9libs\houpythonportion\ui.py", line 1119, in decorator
return func(*args, **kwargs)
File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.640/houdini/python3.9libs\hou.py", line 52202, in merge
return _hou.hipFile_merge(self, *args, **kwargs)
hou.OperationFailed: The attempted operation failed.
Node cook is in progress: /stage/pythonscript1
What I am doing wrong?
can you post the script ?
A bit hard to debug without the source code.
That being said i have also had issues using kwargs inside a python node.
I wouldn't advise doing that in a live python node, that's usually to modify the stage itself, not the scene nodegraph
do you really want to merge file every time that node is cooked? that can lead to all sorts of issues and I wouldn't be surprised if some operations were not allowed during cook
Edited by tamte - Nov. 30, 2023 16:28:32
