Pop Grains with different mass
   1277   1   0
Hi everybody,
How can I vary the mass for grains? I assign point wrangle after grainsource and try to alter the mass (or even density) parameter and it does not seem to change the weight.
Is it totally wrong?
Try the same alterations in a pop wrangle inside the solver instead of on the SOP level, see if that does the trick.
