When sending a USD render job to Hqueue, I'm having a problem when the USD is generated by Windows and the render happens on a Linux machine. I think the output path gets evaluated at the USD creation step and the Linux render fails. Any ideas on how to circumvent this.
Using $HQROOT on the output image path/field in the karma LOP. If it all runs on either OS it works. It's when mixing that it doesn't.
Is there anyway to send a job that doesn't separate USD creation and rendering?
USD Render Hqueue Linux/Windows Problem
431 2 0- dany27227
- 22 posts
- dany27227
- 22 posts
- dany27227
- 22 posts
Looking at the command that runs on Linux I see the input path still has the $HQROOT while the output path has been evaluated (on the windows machine to "G:") ...
The Houdini 20.0.590 environment has been initialized. Karma Command: $HFS/bin/husk -R BRAY_HdKarma --verbose-callback "$HFS/houdini/scripts/hqueue/hq_karma_stats.py" --verbose "1" --frame "20" --make-output-path --output "G:/Projects/BoatWater/render/Test8.0020.exr" --usd-input "$HQROOT/Projects/BoatWater/usds/farmTest-0020/__render__.usdnc" [19:19:19] /opt/hfs20.0/bin/husk version 20.0.590 [19:19:25] WARNING: Entered non-commercial session mode. [19:19:26] Using stage default settings: /Render/rendersettings [19:19:26] Unable to create output directory path: G:/Projects/BoatWater/render PROGRESS: 0% [19:19:26] >>> Render G:/Projects/BoatWater/render/Test8.0020.exr (1 of 1) - 960x540 /mnt/G/Projects/BoatWater/usds/farmTest-0020/__render__.usdnc frame: 20 PROGRESS: 0% PROGRESS: 0% PROGRESS: 1% PROGRESS: 9% PROGRESS: 16% PROGRESS: 25% PROGRESS: 34% PROGRESS: 43% PROGRESS: 54% PROGRESS: 63% PROGRESS: 72% PROGRESS: 82% PROGRESS: 92% PROGRESS: 100% [19:19:41] Total Wall Clock Time: 0:00:22.54 [19:19:41] Total CPU Time: 0:01:05.84 [19:19:41] System CPU Time Only: 0:00:28.84 [19:19:41] Current Memory Usage: 974.14 MiB [19:19:41] Peak Memory Usage: 974.14 MiB [19:19:41] Unable to write to image: G:/Projects/BoatWater/render/Test8.0020.exr Error: Failed to create file "G:/Projects/BoatWater/render/Test8.0020.exr : No such file or directory". Traceback (most recent call last): File "/opt/hfs20.0.590/houdini/scripts/hqueue/hqlib.py", line 2219, in main function(**kwargs) File "/opt/hfs20.0.590/houdini/scripts/hqueue/hqlib.py", line 404, in invokeKarma _invokeKarmaForOneUSD( File "/opt/hfs20.0.590/houdini/scripts/hqueue/hqlib.py", line 434, in _invokeKarmaForOneUSD _exitApp(pipe.returncode) File "/opt/hfs20.0.590/houdini/scripts/hqueue/hqlib.py", line 2539, in _exitApp sys.exit(return_code) SystemExit: 1
