Is it possible to insert Qt/PySide widgets into a node's parameters UI so that I have a mix of Houdini parms and Qt widgets?
I know you can create a custom PySide panel, but this seems like an all or nothing solution.
Plus when you create your own Python Panel UI you lose the benefits you get with the built in parms UI such as expression evaluation.
I mean, yes, I could recreate these widgets for PySide panels, but why reinvent the wheel?
Can I insert Qt/PySide widgets into a node's parameters UI
190 0 1- erikcarlson
- 19 posts
