Short of creating a real skeleton with a radius and ulna bone and simulated muscles, how would one create a twist for a wrist?
Given that the human hand can rotate about 180 degrees (270 if you also use your humerus/shoulder joint) relying on the three traditional joints (shoulder, elbow, wrist) only for the arm doesn't work well.
The technique, while not perfect, of creating multiple bones/joints for the forearm that rotate progressively slower from wrist to elbow, is a good solution for preserving most of the forearm mesh volume.
What would be the setup in a rig vop for something similar? Or any solution for kinefx.
KineFX wrist twist - how?
1913 3 1-
- citizen
- 113 posts
- william_harley
- 122 posts
citizen
The rigpose can output the transform parameters as attributes. In this example, Im using the "r" point attribute to rotate the local xforms of the twist joints.
- citizen
- 113 posts
- citizen
- 113 posts
Hi William,
Please help me understand a few things if you can:
1stly, why does one have to set joint transforms (setpointtransform) inside the twist_setup rigVOP for each bone in the hierarchy?
2ndly, can one set them in a different way (all at once)? Because right now seems like I have to do it for each joint, above (shoulder, clavicle, etc) and below (fingers) the wrist joints and they're quite a few.
Edited by citizen - Dec. 4, 2024 10:25:01
