lopimportcam cameras in an objnetwork in solaris don't show in viewport
   1423   3   0
Hi!
I am trying in different Houdini versions (19.0 and 20.0) to load a camera inside an OBJ network in stage. However, it is not shwoing in the viewport camera list.
Is this the expected behavior?
Edited by Cicuta - June 11, 2024 15:38:47
I'm confused, what are you trying? There are object cameras and USD cameras, and each is only visible in their respective contexts.
You have a lopimport camera in an objectnetwork in /stage that is importing a usd camera from somewhere, and that camera doesn't show up in the viewport camera list when you are inside of that object network? A camera in an object network won't appear in the viewport menu when viewing a LOP network.
If you go inside an object network inside /stage, the viewport changes to OBJ. Inside that object network (/stage/objectnet/), any camera you create via camera node or bring via lopimportcam (/stage/objectnet/cam1, /stage/objectnet/lopcam1...), won't appear in the viewport camera menu (obj viewport). You can use them in any /geo context, but they won't appear in the viewport camera menu.
Sorry if I explained myself poorly.
Edited by Cicuta - June 11, 2024 16:20:33
Cicuta
Ah yes, I think I remember this limitation. That menu of the sceneviewer only looks in the root of /obj, so can't find any cameras in an objnet. You can still drag and drop to look through a camera in an objnet though. It's true of any context, not just /stage
