It seems that I still have a problem with the biped_auto_rig, in that when the script is done I have no skin to work with.
I dive down into the skin network and set the File__source from_file sop to my geometry only to develop an error at the rightside group sop.
I mentioned the problem here http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=9696 [sidefx.com]
I also noticed that the mirrorgroup group sop has the same expression, which if it worked would give the rightside and the mirrorgroup the same points. Right?
I am now using version 9.0.734 win64
on a previous version 9.0.727 I tried both the 32 and 64 bit version and got the same problem.
I even tried the expression with a box set to polygon mesh with the same results.
Here is a screen shot of the error report (MMB on rightside sop).
Bug:group sop expressions
4964 4 0- anon_user_54555117
- 69 posts
- graham
- 1907 posts
I'm really not sure what is causing the problem with the group expression. If you wouldn't mind sending me the otl and geometry file I can try and track the problem down.
As for the right side and mirror group, they differ in that one is a point group and the other is primitives. Upon closer analysis they actually appear to have their names switched.
- graham
- 1907 posts
Actually never mind. Since you were nice enough to post a screenshot I can tell you that the problem is that the node has its script language set to Python. I'm guessing you have your default expression language set to Python. Changing it to Hscript will fix that.
Alternatively, you could replace $TX < 0 with
pwd().curPoint().position() < 0 so it would work with python.
I'll look at adding a check for node language so this doesn't happen again.
- 69 posts
- graham
- 1907 posts
